2001 CBR929 cutting out while riding.
Old Dec 7, 2016 | 02:11 AM
Rickycbr929's Avatar
Default 2001 CBR929 cutting out while riding.
Since I bought the bike from day 1 it was cutting out at higher speeds. Now it cuts out and the idle reduces and dies at lower speeds.
34 + 35 blinks I thought the fault was associated with an aftermarket exhaust being fitted. I'm waiting for a servo buddy to come from England to correct these codes.
Though, according to the workshop manual 34 + 35 shouldn't effect the running of the bike I'm thinking this isn't causing my problem.
It appears to happen on acceleration and decel. If I'm cruising along I can bump start it again.
Today I cleaned the Kill switch and the starter switch.
I bypassed the bank (tip over sensor) and it's still acting up the same way. I couldn't get the bank angle sensor off to test as per manual 5-88 as the two retaining screws are chewed up. Why I bypassed.
At the moment going through the manual to try and get a clue It's a nice warm sunny day in Thailand. Cup of tea in hand I'll go back to the bike and look at the engine stop relay.
Guys. Any pointers in the right direction would be appreciated.
Old Dec 7, 2016 | 02:29 AM
CaBaRet's Avatar
Hi Ricky , have a look at the FPR ,run a test to see if it's working OK.
Old Dec 7, 2016 | 02:34 AM
Hi CaBaRet.
FPR? where is that located please. Fuel Pressure regulator?
Old Dec 7, 2016 | 02:58 AM
CaBaRet's Avatar
Sorry Ricky , yes Fuel Pressure Regulator , the diaphram in the regulator can perish.
Page 5-56 of your manual
Old Dec 7, 2016 | 04:33 AM
I went over a few things. Cleaned the contacts on the engine stop relay and fuel cut relay.
Looked at the regulator it was dry. No signs of leakage.
Closed the tank and had a quick look underneath.
Hmm... looks like the main fuel supply line is badly kinked when the tank in the closed position. It's steel braid. How easy is it to remove this fuel line?
Attached Thumbnails 2001 CBR929 cutting out while riding.-fuel-line-1-.jpg   2001 CBR929 cutting out while riding.-fuel-line-2-.jpg
Old Dec 7, 2016 | 05:12 AM
CaBaRet's Avatar
I'd just remove it , let it find it's own natural state and re-install
Old Dec 7, 2016 | 05:41 AM
I'll try that tomorrow. It looks as though the ends have been brazed or soldered on. It's not Honda's fuel pipe. Hopefully that's the problem.
Old Dec 15, 2016 | 03:22 PM
ceebeeaarguy's Avatar
But would a kinked fuel line result in an fi error code?
Sometimes weak spark plugs may result in engine cutting off on sudden throttle inputs?
Old Dec 16, 2016 | 02:21 AM
dec111's Avatar
No.
You checked battery readings?
When was plugs last done?
grumpy304
Sep 13, 2011 11:59 AM
alphakilo
Mar 28, 2010 08:19 PM
u03am5
Aug 25, 2009 04:51 PM
supersnake83
Aug 23, 2009 09:40 PM
dsfnuttz
Sep 4, 2008 05:08 AM
