1994 Carb vent hoses
Old Aug 10, 2024 | 04:07 AM
Cameaparteasier's Avatar
Default 1994 Carb vent hoses
Can anyone tell me where the two carb vent hoses normally live? I didn’t pay much attention when I lifted the carburettor off? I have them dropping straight down below the carb at the moment, but don’t think this is correct.
Also, mine doesn’t seem to have a fuel pump, just a pipe from the fuel tank going straight to the carbs and then a small pipe from the carb to the petcock, vacuum hose I think. Would this be a stock setup or has the fuel pump been deleted?
Old Aug 16, 2024 | 03:27 PM
The carb vents should follow the fuel vent pipe down the side of the bike through a little cutout at the bottom of the fairing L/H side I think.
The F2 was gravity fed, so no fuel pump.
Old Aug 16, 2024 | 08:12 PM
Cheers for the info, I found a tiny picture in the Haynes manual showing the hoses clamped either side of the frame via a hook shaped piece attached to the frame. They kind of follow the tank around to the crotch area then aim them downward. This is as far as the hoses would reach. I really need to start taking pictures whenever I take things apart.
Is there some kind of serviceable filter in the tank or in the petcock?
Old Aug 17, 2024 | 11:00 AM
May have given you some duff advice, according to this parts fiche the 1994 may have had a fuel pump:
https://hondaspareparts.co.uk/pages/...29_FUEL_TANK/y
Not sure what vin number yours is, but have a look.
There is a strainer that is on the petcock internal to the tank and on the above picture it looks like there is an in line filter also from the fuel pump.
Old Aug 17, 2024 | 11:11 AM
To be honest, I am unfamiliar with these machines as I have never owned Honda, but the first thing that popped into my head, when I had the tank off to clean the carbs, was, where is the fuel pump? Someone may have deleted it and made it gravity only. It seems to be running fine as it is though, however I have not had it out for a run yet, as it’s not road legal at this moment in time.
Rookie77
Mar 24, 2018 08:46 PM
Hootie233
Jan 24, 2011 08:12 PM
lostnawave
May 16, 2007 09:30 PM
nkx
Apr 5, 2006 03:48 PM
Main
May 17, 2005 01:06 AM
