-1 front + 2 rear
Old May 30, 2006 | 10:11 PM
03954guy's Avatar
Default -1 front + 2 rear
if i go withis particular sprocket set up will i need to remove/add chain ? i don't think that i will have to because the slack from the missing front one will be taken up by the additional rear two and there is some room to adjust and the bike also calls for 1.75 inches of free play in chain so i think i won't have to remove/add chain links let me know
Old May 30, 2006 | 11:35 PM
lang1864's Avatar
Default RE: -1 front + 2 rear
If your doing this you should just go and get a new 520 chain instead. Alot better
J
Old May 30, 2006 | 11:45 PM
03954guy's Avatar
honestly do you really think that a chain made a difference or the gear ratio change by the sprockets ?
Old May 31, 2006 | 01:38 AM
lang1864's Avatar
Do i personally think the chain made a difference, i would say no. I think its all the sprockets. But since i was doing it i figured i would spend a little more and get a new stronger and better chain. Just my own opinion. Do what ever u feel like.
J
Old May 31, 2006 | 01:43 AM
The Twisted Grip's Avatar
One tooth in the front is almost equivalent to three on the rear, gear ratio wise, so i woul guess that the chain will adjust properly with that setup. also, i own a bike shop here in russellville and i know that those quick accelleration kits that use 520 chain and aluminum rears, dont last. the "rolling mass" reduction is knit picking. the gear ratio is where the gain is. but that's only my opinion. thanks for the tip on my problem.
Old May 31, 2006 | 03:50 AM
DThompson's Avatar
Dont bother getting a 520 kit for a 600CC bike. If you look up on that, it really doesnt do anything for that size bike. They were made for 1000CC bikes.
And by the way a 520 is thinner and will break easier. It isnt stronger
Old May 31, 2006 | 08:31 AM
sredlihcm's Avatar
Any time you change a sprocket/chain you need to repalce the other. no matter which one you change for what ever reason up in the front down in the back, front down a$$ up you know.
amig
F2 For Sale / Trade / Wanted
Nov 9, 2010 09:05 PM
handiddy
Jun 27, 2008 08:47 PM
kroymander
Sep 27, 2005 01:42 AM
