-1 front + 2 rear
if i go withis particular sprocket set up will i need to remove/add chain ? i don't think that i will have to because the slack from the missing front one will be taken up by the additional rear two and there is some room to adjust and the bike also calls for 1.75 inches of free play in chain so i think i won't have to remove/add chain links let me know
One tooth in the front is almost equivalent to three on the rear, gear ratio wise, so i woul guess that the chain will adjust properly with that setup. also, i own a bike shop here in russellville and i know that those quick accelleration kits that use 520 chain and aluminum rears, dont last. the "rolling mass" reduction is knit picking. the gear ratio is where the gain is. but that's only my opinion. thanks for the tip on my problem.
