06' cbr 600 f4i throttle body sync question?
Old May 3, 2014 | 09:48 PM
wadmancpu's Avatar
Default 06' cbr 600 f4i throttle body sync question?
I just did the plugs and a valve adjustment on my cbr, I also sync'd the throttle body. Now I'm not sure if I did the sync properly. I got all the cylinders even at idle and tried to find a reasonable balance between idle and the higher rpm range. Should I have just sync'd it at idle and not the higher rpm range? I found at a level 3,000 rpm one of the cylinders would completely loose its fluid. I was able to balance this out fairly well. I just wasn't sure if this was an "idle only adjustment"? I saw a site where a guy was balancing between ranges so that's why I went that route. Any ideas? Thanks!
Old May 5, 2014 | 09:48 AM
jskateborders's Avatar
Registered Users
I've always just synced at idle and had no issues so I would recommend sticking to that. If you have to adjust your plates to sync at a higher rpm it will throw off the sync at idle.
Old May 5, 2014 | 11:04 PM
wadmancpu's Avatar
That's why I found "middle ground" between idle and higher rpm. Before I did it the sync was way off at both idle and higher rpm. You have to give a little on each end but you can get it fairly close if you play with it enough. I just wasn't sure if there is any gain to doing it this way and if anyone else has also. The link below is to a page I followed.
https://home.comcast.net/~nstama/f4i...ebodysync.html
Old May 11, 2014 | 02:31 PM
boredandstroked's Avatar
Download the service manual that is linked in the forum stickys and do it as Honda says.
Old May 13, 2014 | 07:36 AM
wadmancpu's Avatar
Thanks. I just re-synched it at idle only as the manual says. Haven't been out yet to check it out because of rain and life's usual BS.
mikeyg2487
Jul 19, 2015 09:46 PM
JedGoingHam
Mar 25, 2014 07:47 PM
MC_spirited
Apr 6, 2009 04:48 PM
slip_
Feb 21, 2008 04:37 PM
littleman
Apr 15, 2007 05:38 PM
