05 600RR FI/GAUGE problems HELP!!!!
picke the bike up a couple weeks ago fully stock i put a jardine slip on and now when i ride it the FI light comes on and my gauges flicker off for a second and flicker right back on can anyone help me pleaseeee!!!!!
Did you reconnect the O2 sensor when you swapped the exhaust or did you delete it? Does the FI light stay on or blink a code? As for the gauges, you may have a loose connection to the gauge or somewhere in the harness. I will elaborate on the O2 sensor if you deleted it...
Check to make sure the O2 sensor is there, that will cause the FI light to come on. If it is there, use your manual to see what code the FI light is throwing. That will tell you where you need to look.
Here is a link to download the manual:
http://downloads.hondatech.info/Moto...2801-03%29.pdf
Says 01-03, will also work for your 05.
See what code it's giving you and we can go from there...
http://downloads.hondatech.info/Moto...e%20Manual.pdf
Good luck. Just let me know if you need anything.
