02 954 wont fire,please help
Old Jun 2, 2005 | 06:52 PM
wish68ss's Avatar
Default 02 954 wont fire,please help
Need help please.I have a 02 954,i pulled the engine covers to be chromed,and switched fuel tanks with an identical bike.Both bikes were running fine.Now one wont start.I pulled a spark plug and turned it over,but no spark.All fuses by battery are ok.The Honda shop guru[some guru] said something like switch the ignition key set,something about a anti theft resistor that might of went out.Please help
Old Jun 15, 2005 | 01:00 AM
Capone's Avatar
Default RE: 02 954 wont fire,please help
This might not help to much, but I learned it through expirience.. if it ran fine before you took it apart, and you didn't break anything taking it apart - putting it back together, then the chances are you didn't hook something up. I wouldn't go replacing parts just yet. Make sure all connections to everything under tank is secure, double check everything you disconnected.
rocco787
Jul 13, 2012 10:59 AM
nicksauce
Jul 9, 2012 03:45 PM
bowflexmaverick
Feb 8, 2011 08:12 PM
ktm851
Nov 18, 2007 01:33 AM
smokey_d38
Sep 25, 2007 08:02 AM
