Cbr f4i wont fire
Old Feb 5, 2011 | 12:31 PM
bowflexmaverick's Avatar
Default Cbr f4i wont fire
Ok on my 2002 F4I i fired it up 2 days ago flawlessly, Went to do it today, and got it to go. It stayed on for about 1 minute being very rough. Shot some flames out the exhaust and then died. Now I can't get it to ignite and am unsure what to do. It's not the BAS, kill switch, I took everything off and dumped fuel into the throttle bodies. Nothing. It tries to start and you hear a deep engine noise every little bit, but never goes all the way. Battery has been charged and good to go and I'm running out of ideas. Please any help would be great.
Old Feb 5, 2011 | 01:08 PM
And it is not the ECU, just barely swapped out a clean one. Checked all fuses as well.
Old Feb 5, 2011 | 01:09 PM
jp_greenville13's Avatar
Pump priming? Injectors pulsing?
Spark?
Old Feb 5, 2011 | 01:19 PM
Fuel pump is priming, not sure how to check for injectors pulsing. And this may be dumb, but how do you usually check for spark?
Old Feb 5, 2011 | 01:25 PM
To check for spark you can use an in line spark tester or simply remove the spark plug, Ground the electrode and crank the bike with the wire on the plug. You'll see it spark.
To check injector pulse you'll need a noid light which can be bought fairly cheap or made (google it).
Not to ask the obvious but are you sure it's got gas in it?
Old Feb 5, 2011 | 01:27 PM
Haha yes learned that lesson from the last time. I'll check that stuff out. Question, if you dump fuel in the cylinders directly then shouldn't it fire up?
Old Feb 5, 2011 | 01:30 PM
Assuming you didn't pour too much. I use brakleen because it's more of a fume than a liquid
Old Feb 5, 2011 | 01:34 PM
Hmmm ok, I'll go check the plugs injectors, and re check the battery.
Old Feb 5, 2011 | 05:15 PM
updates?
Old Feb 7, 2011 | 06:57 PM
Pretty sure its the spark, it was barely shootin out spark when it was being cranked. Gonna order em in and swap em out tomorrow.
