01 F4i Led Turn signal wiring question
Old Jan 28, 2024 | 11:53 PM
Saltcreep's Avatar
Default 01 F4i Led Turn signal wiring question
Hi all. I'm replacing some old flush mount led turn signals with same profile flush mount smoke led turn signals. When I connect the new ones wire for wire it doesn't work. The old ones didn't work for a while so I don't know if it's the wiring, the lights or something else.
The new signals have a black and a yellow wire. Out of the two harnesses, from one there's an orange with white wire and an orange wire, and from the other there's a green wire. The black was connected to the green, the yellow was connected to the orange. The orange and white wire from the harness was capped off. .When I did the same with the new lights it didn't work. I'm attaching pics.
Does the wiring seem right and I have some other problem?
Old Jan 29, 2024 | 02:47 AM
dannoxyz's Avatar
Your problem doesn’t have anything to do with wiring. You just don’t have any power going out those wires to lights. Learn this, it’s 5-minute fix with multimeter.
https://learn.sparkfun.com/tutorials...multimeter/all
As test, connect your old lights directly to battery: blk to negative terminal, yel or red to positive. Bet they turn on huh?
Best to install factory OEM connectors on aftermarket lights for easy plug-n-play installation like this:
https://www.corsa-technic.com/item.php?item_id=415
You can even install 2x diodes per side and get both marker lights AND blinker functions working just like stock 2-filament bulbs! Better visibility and higher safety!
Attached Thumbnails 01 F4i Led Turn signal wiring question-cbr600-frontturnsignalconnectors.jpeg
Old Jan 29, 2024 | 01:09 PM
Saltcreep's Avatar
Thanks Danno for the thorough feedback. I'm on it.
Old Jan 29, 2024 | 01:51 PM
dannoxyz's Avatar
You’re welcome! To find out where power disappears, do series of measurements to trace electricity flow through circuit:
1. Battery, volts = ???
2. Power into ignition-switch red wire, volts = ???
3. Key On, measure power out of ignition-switch, red/blk, volts = ??
4. measure power out of fusebox wht/grn wire, volts = ??
5. Flip signal switch L or R, measure power into signal switch, gry, volts = ??? (pulsing)
6. measure power at winker bulb wire, O=Left, LiteBlu=right, volts = ??? (pulsing)
You’ll make series of measurements like 13v -> 13v -> 13v -> 0v <— aHAH!!! Problem is between that latest junction measured with zero power and previous measured point that did have power! Most of time it’s corroded signal switch (open up, spray WD40 on contacts, flip switch back & forth). Or broken wire, measure end-to-end to make sure it’s working.
boredandstroked
Aug 19, 2012 07:52 AM
jch82
Dec 22, 2011 10:59 PM
nrmskate
Jan 4, 2011 10:14 PM
Paulalmighty
Feb 9, 2009 07:57 PM
socal22
Nov 2, 2007 01:06 PM
