Forum Help & Suggestion Center Need help with CBR Forum? Ask. Have a suggestion to better CBRF? Tell us here. DO NOT POST QUESTIONS ABOUT YOUR BIKE HERE.
93 f2 issues
Old Aug 19, 2023 | 04:24 AM
Blev's Avatar
Default 93 f2 issues
Charge my battery for a whole day to a 100% after trying to crank bike for Less Than 3 minutes battery dying already and bike won't turn over before charging my starter was just making a clicking noise before all this started bike died on the way home the other day I thought I ran out of gas but there was gas in the tank I walked home came back with a jump pack bike started up went to ride the bike the next day and I wasn't getting any power it was like bogging out so that's where it all started I cleaned out the carburetor on the bike so I wasn't able to clean all the Jets and everything else thoroughly I changed the oil and changed the oil filter and the spark plugs one of my spark plug boots had a rip in it but I repaired it and it seems to have fine Spark I'm lost here my gas tank vent is clear my vacuum hose is working my pet **** is working
Old Aug 19, 2023 | 09:42 AM
Start with a new battery sounds like it is toast. If it is not holding charge then bike will shut down, then check the voltage across the battery should be c. 15v at 5k revs. Id that is ok stator and coils are fine.
Old Aug 20, 2023 | 01:45 PM
dannoxyz's Avatar
dead battery!
Starter solenoid clicking and having it run OK with jump-start shows battery is dead and not holding charge.
As mentioned, test and verify that charging system is Ok, otherwise new battery will just die slow painful death.
https://www.vfrdiscussion.com/index....719-the-drill/
Old Aug 21, 2023 | 11:23 PM
Blev's Avatar
Default 93 cbr f2 600 streetfighter
Originally Posted by dannoxyz
dead battery!
Would the symptoms of compromised Battery/charging system include the Following....* throttle response in neutral is normal but in gear riding loses power the more throttle given..if bike runs a full day then isn't driven for 2-3 days results in hard
start ...the bike only has about 5-10 tries cranking then will need jump pack.
Also my choke cable resently snapped..
Key was stolen from a looser who can't work hard and get their own bike so they try to plot on me. So I forced it with screwdriver now turns freely. Is there maybe a safety in ignition that could cause sometimes no starts or problems in any way...
I put a lot of time and effort into this bike and it's killing me that it's not running right now I just want to get it right
Old Aug 21, 2023 | 11:32 PM
dannoxyz's Avatar
You've got multiple problems.
1. dead battery for sure.
2. might be caused by bad charging system, test & measure to verify
3. may have parasitic drain that's killing battery when sitting
4. throttle issue is most likely clogged fuel-filter or failing pump. Most likely dirty clogged carbs that need full disassembly for full restoration job.
Blev
Aug 19, 2023 04:23 AM
Alex Parrett
May 12, 2021 10:46 AM
Kiwi born
F2 Media
Mar 19, 2014 04:46 PM
outsider
F2 Media
Jan 7, 2014 03:34 PM
AEngineer85
F2 Media
Feb 6, 2011 09:31 AM
