Wont start. no fuel pump sound
Hi everyone, new here and I ran into a weird problem. the 600 was riding fine for 2 hours the day before. When I went out to start it today, I noticed both signal lights, regular blue lights, red light, and flashing oil light was on. I then switched the engine stop switch to on and I did not hear any "hmmmmm" sound. I still tried starting it several times but it didnt start. After several times the gas light on the left side of the indicator came on. (tried starting too many times I assume?) I disconnected the battery for awhile and the gas indicator went away, but the fuel pump still does not make a sound. Whats going on here! I checked the fuses but they are all good.
Should I be lifting the tank up and checking the fuel pump?
Guest
Posts: n/a
Check the two relays that are attached to the right hand side of the subframe, under your tail cowling. One of them is a fuelpump kill relay. Also just go around and check all the plugs in the harness and make sure everything is making a good connection. Alot of these problems end up being a harness problemm one of the relaysm or a bad connection. By the way, that the kill switch your using isn't really there to stop the bike, it's an emergency stop deal, a normal stop on the bike just requires use of the ignition switch. Supposed to just turn off the key to stop the bike.
C Jacob W
07-29-2013 11:03 AM
Turboedsupe
10-06-2009 02:45 AM
