won't start
Old Oct 29, 2005 | 08:40 PM
APCh8r's Avatar
Default won't start
Alright came home from school and went to put fuel stabilizer in the bike for the winter. Went to go start it after i put it in to let it run through the lines and everything and the bike would not start. Now I do have the whole front end off because i am replacing the forks and everything. Is there some safety measure that is stopping the bike from starting or what do you guys think is going on. Any help would be appreciated!
Old Oct 29, 2005 | 09:19 PM
OutToWin PAHC's Avatar
Default RE: won't start
your cut off switch is wired threw the headlight wire harness so if you have the lamp pulled which you probably do that it.
Old Oct 30, 2005 | 05:39 PM
APCh8r's Avatar
so do you guys think it will be okay with the stabilizer just sitting in the tank since i couldn't get the bike to start to run it through the fuel lines. I really can't get back to home to put the front end back on to get this thing to start. Tell me what you guys think.
Old Oct 30, 2005 | 10:19 PM
1badf4's Avatar
it depends on how long it sits. Will it start? Most likely but it will run like crap. You have un-stabilized gas sitting in the lines. You should get it started and the gas run through as soon as you can.
Old Nov 3, 2005 | 12:45 AM
mxman87's Avatar
If you haven't got it started yet another possibility is you have the bank angle sensor unplugged which is mounted behing the headlights, so I assume you have that off also.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
