Wiring up undertail
Old Mar 26, 2007 | 08:12 PM
TranSition's Avatar
Default Wiring up undertail
I am in the process of wiring up my taillights on my undertail. I am aware that on the F4i the green wires are the grounds... On the turn signals no problems with only 2 wires. However on the LED brake lights I have a black, red, and brown, and then the 3 wires on the Honda harness. ANyone know for sure which I wire the brown and red to on the F4i Harness?
Old Mar 26, 2007 | 09:06 PM
F4Isvt's Avatar
Default RE: Wiring up undertail
I dont know of the top of my head but turn your bike on and test them with a test light to see which is brake and which is running
Old Mar 26, 2007 | 09:50 PM
smak_blaze's Avatar
Your red wire on the signalwill go to the solid color wire on the bike w/o the white stripe, the brown on the turn signalwill go to the wire with the white stripe and the black wire on the turn signal goesto the brown on the bike.
Old Mar 26, 2007 | 10:55 PM
jayking232003's Avatar
What year model is your bike? I just did mine, its an 2001, I'll walk out there and look, but it sounds like they are all different,, I remember 2 sets of 3 wires coming out of the harness, the green was ground. one of the was running lights and one was brake lights, two left extra for blinkers,,,****.... let me go look
Old Mar 26, 2007 | 11:06 PM
yellow to red,, brown to white,, thats how mine was,,, i had four wires on the undertail to hook up. 1 for the blinker, one for the ground and the other two are connect as above.. hope that helps man,,,, I will say this,, when I say yellow to red I mean the line, not the solid color of the wire
Old Mar 26, 2007 | 11:51 PM
smak_blaze's Avatar
He has a red brown and black on his turns. I need to revise what I typed in my post. THE BLACK ON THE TURN NEEDS TO GO TO THE GREEN WIRE ON THE BIKE NOT THE BROWN (BECAUSE THERE ISN'T ONE) SORRY.
Old Mar 27, 2007 | 12:21 AM
TranSition's Avatar
all gravy i searched and found my volt/amp meter. Wired her all up correctly. Beautiful and oh so damn bright! Just waiting on my vertical swingarm plate mount to get here and I am all done with preseason upgrades. Thanks for everyones input
Old May 14, 2007 | 05:13 PM
mattyrides07's Avatar
ORIGINAL: TranSition
How did you find this? I'm stuck putting mine on- different make of undertail...HELP!
rikubot
Jan 1, 2019 06:09 PM
mattnadz
Jun 26, 2012 11:24 AM
That929
Feb 1, 2009 11:10 PM
jboice06
Nov 11, 2007 12:30 PM
JAY 2002CBR
May 18, 2006 09:10 PM
