NEED HELP WIRING UNDERTAIL KIT ON A 01 F4I
HEY GUYS I BOUGHT AN UNDERTAIL KIT ON EBAY AND NEED HELP WIRING IT UP........... THE 2 LIGHTS HAVE THE INTEGRATED TAIL LIGHTS IN THEM THEY HAVE FOUR WIRES BLUE RED YELLOW BLACK.......... SO IM LOST AND THE POS CAME WITH NO DIRECTIONS.... PLEASE HELP GUYS
RE: NEED HELP WIRING UNDERTAIL KIT ON A 01 F4I
Ok. I have four wires per light as well. Two of the wires are different but hopefully this will help.
Red wires from light should go to the Green wires with yellow stripe.
Black wires from the light should go to the solid green wires.
Now the rest for you will be a puzzle.
One of the turn signals will connect to the orange wire and the other to the blue wire.
The last of the two remaining same colored wires will connect to the black with tan stripe.
Hopefully this does not confuse you more. Good luck.
If you want you can pm me and I will try to talk you through it or you can call me. PM me and we will make it happen
easiest way to test whats what. get some wires and connect the lead ends to the battery. i thing that th black wire is the ground for your kit. so have the black connected to the - side and probe all the rest to the +.
the wiring pics is absolutely blurry.
