wiring help
Old 10-23-2007, 11:43 PM
adam0220's Avatar
Default wiring help
Guys, I need your wiring help. I am currently trying to install flexible led strips on my F4i and was wondering thebest place to run the ground from the switch to. I know to run from the battery to a fuse then to one terminal, the middle terminal will run to the positive of all the led's, wired in parallel, but the third terminal needs a ground. When can I run the ground to? Thanks for the help.
Old 10-24-2007, 01:09 AM
ampfp's Avatar
Default RE: wiring help
That would be the negative terminal of the battery...
Old 10-24-2007, 01:54 AM
FLYOU's Avatar
ORIGINAL: ampfp
+1
you can also ground it to the frame i believe, as long as it's making contact with the bare metal and not the powder coat.
then again i'm not a scientist.
Old 10-24-2007, 05:55 AM
Aken's Avatar
July 2008 ROTM
I grounded all my lights straight to the battery.
bigwill74
03-05-2013 02:56 PM
leonf4i
10-10-2009 07:24 PM
AALBA2
03-31-2008 08:55 AM
93_ka24det
03-25-2007 06:38 AM
mastice
11-26-2005 04:37 AM
Quick Reply: wiring help
