wiring help
wiring help
Guys, I need your wiring help. I am currently trying to install flexible led strips on my F4i and was wondering thebest place to run the ground from the switch to. I know to run from the battery to a fuse then to one terminal, the middle terminal will run to the positive of all the led's, wired in parallel, but the third terminal needs a ground. When can I run the ground to? Thanks for the help.
