Wiring Help
Old Oct 13, 2007 | 04:16 PM
bakesf4i's Avatar
Default Wiring Help
So I just finished wiring up my hotbodies flush mounts. I wired them up with the diodes so they would also work as running lights and everything works fine. The problem is that when I hooked up my rear turn signals (non l.e.d.) and activate my turn signals say to the left, the rear left turn signal wont work at all and the the front wont work either. Then when I deactivate it the front works fine again as a running light. Anyone have any ideas? Thanks for the help
Old Oct 13, 2007 | 07:01 PM
oodie's Avatar
February 2009 ROTM
Default RE: Wiring Help
Your wiring is not right check it out again.
Old Oct 13, 2007 | 07:23 PM
02cbrf4i4u's Avatar
Yea something is connected wrong....remember green is ground
Old Oct 13, 2007 | 09:39 PM
bakesf4i's Avatar
Yeah I think I might have mixed up the wires when i was soldering my tailights together I find it hard to believe that I would do it twice but anything can happen. Hopefully thats what it is because that would be the easiest fix, and if not Ill go through all the wiring up front
Old Oct 15, 2007 | 09:49 AM
bakesf4i's Avatar
Ok so i checked over all my wiring and evertying checked out ok, so i took of the diodes and still have the same problem. The running lights work up front but the turn signals wont work at all front or rear. All my fuses are good so i really cant figure out whats goin on. Could it be my relay?
Old Oct 15, 2007 | 05:50 PM
ampfp's Avatar
If you get your wiring wrong once you can short out = burn out stuff. It would be useful to see if the turn signals are getting powered.
To check this, disconnect the turn signal wire from both front and back, take a multimeter and put it to the turn signal wire and ground in voltage mode, and switch on the turn signal. You should see the display change i.e. increase, decrease, increase, decrease. If this doesnt work put one of the 8 ohm resistors across the multimeter and check again.
If you see a changing voltage, means at least your relay is doing ok. Then it's just the diodes/signals. Sure you got the diodes connected in the right polarity?
Old Oct 16, 2007 | 05:15 PM
bakesf4i's Avatar
Alright so I figured out what was goin on with my rear turn signals. Turns out that when I installed the actual turn signal itself I was twisting it aka screwing it into the hole because it was just a tad to small. When I did this the wires inside the signal crossed each other causing them to short circuit. So when I activated the turn signals the rears would short out and thus cut out the front. Thanks for the help!
bigwill74
Mar 5, 2013 02:56 PM
leonf4i
Oct 10, 2009 07:24 PM
AALBA2
Mar 31, 2008 08:55 AM
93_ka24det
Mar 25, 2007 06:38 AM
mastice
Nov 26, 2005 04:37 AM
