Wiring Harness - Power Commander Install
Good day all..
I just recently added a power commander into my 03 'f4I.. It went well - and powers up no worries.
The only issue I had was trying to repack the wiring hardness in back between the engine and the frame..
I was able to wrangle the wires around which worked out -but i am worried I was a bit too rough..
Does anyone know how strong the wiring harness is? - Just worried I broke some wires...
Seeing its -20 outside and the bike is winterized I am not keen on starting it..
Any help would be appreciated.
If a wire snapped because of the cold, you'd know it (-20??? Geez, don't drop a fairing). Your biggest concern is a wire getting pinched or caught between sharp edges. That can cut through the insulation and cause a short.
Simple manhandling won't do anything... Unless you ended up holding a wire connected to nothing
