Wiring Harness - Power Commander Install
Good day all..
I just recently added a power commander into my 03 'f4I.. It went well - and powers up no worries. The only issue I had was trying to repack the wiring hardness in back between the engine and the frame.. I was able to wrangle the wires around which worked out -but i am worried I was a bit too rough.. :icon_doh: Does anyone know how strong the wiring harness is? - Just worried I broke some wires... Seeing its -20 outside and the bike is winterized I am not keen on starting it.. Any help would be appreciated. |
If a wire snapped because of the cold, you'd know it (-20??? Geez, don't drop a fairing). Your biggest concern is a wire getting pinched or caught between sharp edges. That can cut through the insulation and cause a short.
Simple manhandling won't do anything... Unless you ended up holding a wire connected to nothing ;) |
Oh yeah, and I was serious about not dropping a fairing.
It may shatter at that temp |
Thanks - I take all the plastic off and store it in the basement - for cleaning - and ... warmth...
Cheers |
Huskyboy,
does your name have anything to due with the temperature? Where are you located, anyway? |
Sort of - I have 2 Siberian Huskies... - and live here In Ottawa Canada
