Power Commander install problems
Old May 4, 2007 | 05:13 PM
bowtiepwr's Avatar
Default Power Commander install problems
>hey all,
I just attempted to install my Power Commander on my CBR 1000RR and now the engine just cranks and won't fire. I connected theblack wire to the battery (negativeterminal side) and connected the fuel injector harness to the correct ones starting with the orange on the left side injector.
then connected the TPS sensor... but now it just cranks [sm=dontgetit.gif]what am I doing wrong?
Thanks for the help.
Old May 4, 2007 | 06:42 PM
pell's Avatar
Default RE: Power Commander install problems
Does the PC power up when you turn the key on?
Do you hear the fuel pump priming?
I had the same problem when I installed mine, because I took my whole bike apart to get to some other stuff.... Turns out you had to have the headlight plugged in... I dunno if its the same on your bike (mine is a '04 f4i), but its something to think about.
Old May 4, 2007 | 06:43 PM
bowtiepwr's Avatar
>OK I figured it out with the help of DynoJet Tech Support.
it was me hooked up to a connector not the TPS like I thought I am very experianced at taking on and off the mid panels
Old May 4, 2007 | 06:47 PM
bowtiepwr's Avatar
ORIGINAL: pell
>Thanks for the suggestion, but it was me. I had something other than the TPS connected.
I now need my Yoshimura RS5 slip on and I will be all set... for now.
CBRfenatic93
Jun 15, 2012 01:37 PM
King Klong
May 20, 2009 09:03 PM
Glocker23
Feb 21, 2007 02:17 PM
red87tll
Aug 8, 2006 10:03 PM
lang1864
Apr 27, 2006 12:38 AM
