Power Commander 5 install on a 09 600RR
Old Jun 15, 2012 | 01:37 PM
CBRfenatic93's Avatar
Default Power Commander 5 install on a 09 600RR
Step 1: Remove all fairings. (it has come to my attention that you can remove just the tank fairing by itself but is a little harder since the side fairings attached into the tank fairing)
Step 2: Remove gas tank. You don't have to but I found it much easier to work without it on and it takes about 4 mins to take off and saves some stress. Just remember what plugs and hoses go where.
You bike should now look like this.
Step 3: Lay out where your going to run the wire.(I will highlight my route later but for now you can zoom in and get a general idea.)
Step 4: Disconnect the 4 gray plugs that are attached to the brownish color port. Pic below is view from clutch side.
This is where the 4 plugs are located.
Once you have disconnected those wires you will connect your PCV to the brownish ports, and then plug the wires that came off the ports to the PCV wires.
Put your tank and fairings back on and give it a test ride.
King Klong
May 20, 2009 09:03 PM
bowtiepwr
May 4, 2007 06:47 PM
Glocker23
Feb 21, 2007 02:17 PM
red87tll
Aug 8, 2006 10:03 PM
lang1864
Apr 27, 2006 12:38 AM
