Wiring Diagram
Old 04-29-2005, 02:27 AM
02JoeCBR's Avatar
Default Wiring Diagram
Does anyone have a wiring diagram for an 02 F4i? I need to know what each wire is that goes to the rear taillight and turnsignals so i can install my undertail.
Thanks
joe
Old 04-29-2005, 02:14 PM
dlbinford's Avatar
Default RE: Wiring Diagram
I dont have the diagram, but I know if you take you tail faring off they run donw the right side of the sub frame. the tail light has it's ow line, the turn signals and the license plate light are all jumbled together, and have little conectors to disconect the easily. I have a 03 F4i and here is how mine goes.... there is one turn signal connected to a orange conector with green and orange wires, the other turn signalhas a blue conector with blue ane green wires and the license plate light has a wihte conector with brown and green wires. What I wiold do is cut the wires of the stock turn signals and save the conectors. Find out which wires are for the turn signals on your undertail and take the wires with the conector on it and sauder the wires together and the cover with heat shrink. This way once you have all you untertail wire connected, you can just plug them back into the coresponding connectors.
If your a little lost just take your tail faring off and look around the tail light and you should see the colored conectors I am talking about. If your still lost I can try and take a couple of pics to show you what I talking about.
Keep in mind this is all in case the under tail doesn't came with plug and play wire connections, which I figure they would, but I guess not.
[sm=signs003.gif]
CeeBeeARguy
11-01-2013 03:29 AM
fastspares
08-21-2010 10:48 PM
nof900rr
08-06-2009 09:18 AM
95cbrmike
02-07-2009 11:13 AM
acb0173
03-22-2006 10:48 AM
Quick Reply: Wiring Diagram
