Wiring Diagram
I dont have the diagram, but I know if you take you tail faring off they run donw the right side of the sub frame. the tail light has it's ow line, the turn signals and the license plate light are all jumbled together, and have little conectors to disconect the easily. I have a 03 F4i and here is how mine goes.... there is one turn signal connected to a orange conector with green and orange wires, the other turn signalhas a blue conector with blue ane green wires and the license plate light has a wihte conector with brown and green wires. What I wiold do is cut the wires of the stock turn signals and save the conectors. Find out which wires are for the turn signals on your undertail and take the wires with the conector on it and sauder the wires together and the cover with heat shrink. This way once you have all you untertail wire connected, you can just plug them back into the coresponding connectors.
If your a little lost just take your tail faring off and look around the tail light and you should see the colored conectors I am talking about. If your still lost I can try and take a couple of pics to show you what I talking about.
Keep in mind this is all in case the under tail doesn't came with plug and play wire connections, which I figure they would, but I guess not.
[sm=signs003.gif]
[sm=signs003.gif]
