Why does this happen?
Old Nov 22, 2010 | 10:03 PM
  #21
ID_CBRRider's Avatar
Check your head bearing also. It shouldn't be bad on an 06 unless it was wheelied a bunch before you got it. I'd also make sure your tires are balanced. Make sure the weights didn't come off when washing it or when you were riding.
Old Nov 22, 2010 | 10:49 PM
  #22
NateDieselF4i's Avatar
Originally Posted by MuscleswitCBR
Yes I used to compete in the NPC and was doing pretty good. The best I ever came in at was 229 contest shape. Then I had my daughter and had to get a real job and real life started kickin my *** lol. I hope to compete again in the next couple of years.
Very cool. My highest weight ever has been 204 and I used to compete in competitive power lifting. Never did any BB contests though. I'm fairly active on a BB forum as well as here though.
I think my body likes to be around 186-192 at its best.
Its a lot of fun.
Old Nov 22, 2010 | 11:13 PM
  #23
vangill's Avatar
July 2010 ROTM
Originally Posted by __Z__
you see and that would make sense but idk how hed be getting wobble at low speeds with high rpms unless it had something to do with the vibration its causing
its bc at high rpms hes making all the power the bike has, doesnt matter the speed. its like with my new rr, when u get in the high rpms in 1 or 2nd gear and are sitting realxed at the back of the seat and then crack the throttle some more, the front end lifts up. it does it on the f4i too, just not as high which causes a wobble if you dont know whats going one---------------------this may not be whats going on op, but it could be a possibility, regardless of gearing,
i think this thread is about bodybuilding now
and i hate being 140 just for the record, if i could gain i certainly would, but i have failed for years now. getting up to 140 is a record for me.
Old Nov 22, 2010 | 11:25 PM
  #24
motorhorse's Avatar
as stated above i would check the following things(some may be obvious)
tire pressure
blow fork seals
steering head bearings(jack front off ground and feel for any resistance rotating bars)
compression/rebound adjust set properly
i get this sometimes on my bike but its usually while leaning at WOT, not in a straight line. something maybe be wrong, you shouldnt really need a steering stabilizer to mask the problem...
Old Nov 23, 2010 | 12:20 AM
  #25
Kuroshio's Avatar
Um, think there's a question that needs to be asked: What is "high" RPMs?
A newer rider's definition of "high" RPMs may be "cruising" RPMs to an experienced rider. Like I cruise at around 7k-8k. So yeah, if I crack the throttle in that range the front end gets light real quick.
Not real sure on the advice to tighten up on the grips tho. At speed the front has a natural oscillation that's part of the bike's self correcting nature. Get too tight and you begin to fight that correction, which will make it worse. You don't fight a tank slapper by going tight on the bars afterall.
In fact you really shouldn't fight a tank slapper cause you lose
Old Nov 23, 2010 | 06:20 AM
  #26
madman's Avatar
I've had it happen a few times coming hard out of corners or a highway onramp or something. The more it happens the more you're okay with it. Scooting up helps and so does being smoother on the throttle as well as a good even grip on the bars. It's like when you're about to wheelie but never really leave the ground. The damper should help but it's hardly a requirement on this bike, especially on the street.
Old Nov 23, 2010 | 08:01 AM
  #27
__Z__'s Avatar
April 2011 Ride of the Month
as for steering dampers you can find them for various prices
i know some mentioned scotts you can also get
shindy
ohlins
gpr
sprint
harris
shindys are around $250 and prolly the cheapest of them all (unless you find a good deal on a used damper)
Old Nov 23, 2010 | 01:05 PM
  #28
Bently600's Avatar
+1
Your wobble probably happens from accelleration making the front end light... DO NOT tighten your grip on the bars. Most people (myself included) already grip the bars to tightly... if anything loosen your grip on the bars and let the bike sort itself out... the physics involved in a spinning front wheel will naturally straighten you out (unless you are in a huge tank slapper, then your screwed either way).
Old Nov 24, 2010 | 11:24 AM
  #29
MitchA's Avatar
140lbs... I was 140 in 6th grade You guys make me feel like the giant in the group @ 6'1 210.
ryans93honda
F2 Tech
May 21, 2012 02:54 PM
CBRfenatic93
Oct 10, 2011 08:31 PM
Silverbullet1000rr
Dec 8, 2010 09:11 AM
redzintimidator
Apr 1, 2008 08:44 AM
Bumble Bee
Feb 19, 2008 12:01 PM
