Whinning noise from front wheel when riding.
Old Jan 26, 2006 | 12:18 PM
jmabo205's Avatar
Default Whinning noise from front wheel when riding.
When i ride, after a while, i hear a whinning noise coming from the front. it comes and goes, but i'm wondering what this is? if it the rim thats bent or the forks? it sounds like its coming fromt he tires or something over there. its kinda annoying to hear when riding. anyone have some suggestions or ideas what this mite be?
Old Jan 26, 2006 | 12:22 PM
pitsvtec's Avatar
Default RE: Whinning noise from front wheel when riding.
I need a better explanation of the sound....I've got no clue what you mean...sorry!
Old Jan 27, 2006 | 02:02 AM
jmabo205's Avatar
sounds kinda like a grinding but not grinding. hahahaha i don't really know how to say it.... maybe like something is rubbing when the wheel is spinning i don't know.
Old Jan 27, 2006 | 02:13 AM
kiggy74's Avatar
Have you checked your brake pads and rotor in the front?
Old Jan 27, 2006 | 03:04 AM
scotty8583's Avatar
Check your front tire pressure, if it is too low the tire will start to rub on the fender and if you go too long it will warp the front fender. I usually run mine just under 40psi when two-up and it's warm outside.
Old Jan 27, 2006 | 12:56 PM
Tahoe SC's Avatar
i have never heard of this rubbing on the fender thing. it should always clear it...at the track, sometimes tire pressures get down to 22 PSI with some race tire. 40PSI is too high if you're doing hardcore canyon...you better check your fender mang...i think you've installed it incorrectly.
as said before, check your pads...if possible, put the bike on stands and spin the front wheel.
CBR_600_F2
F2 Tech
Apr 3, 2012 08:36 PM
Footnfool
May 24, 2010 03:19 AM
pacemaker
Aug 27, 2007 08:52 PM
japanese900rr
Aug 15, 2006 11:52 PM
