Weird front bearings measurements
Old Mar 9, 2006 | 01:35 AM
Motodollar's Avatar
Default Weird front bearings measurements
Hi.
Does anyone have an idea why did Honda produce the ´04-´05-´06 F4i with a special front wheel bearing size??
20x45x12: Special size.
Normally they are 20x42x12 or 20x47x12 (Both are 6204 ZZ C4),... now I can´t find that size anywhere!!!
Oh!.. By the way, I´m from Chile, so I will have to import the bearings.
Old Mar 9, 2006 | 01:58 AM
brancart1's Avatar
Default RE: Weird front bearings measurements
actually its probably part of Honda's marketing strategy. See this way they make more money. They figure if they make a part no one can just go out and buy, that would prompt the customer to bring the bike into a honda dealer to get it fixed. And usually when new lines of vehicles come out such as the 04-06 models, the aftermarket companies are usually a few years behind in coming out with products for these models. good luck mang.
Old Mar 9, 2006 | 03:59 PM
chaos321's Avatar
The front bearings are different. Even the manual says they are the 6204. The actual measurement is 20x45x1. These numbers come directly from Honda. I had this problem and ruined a front wheel trying to pound in the 6204. Expensive mistake!
Old Mar 10, 2006 | 12:37 AM
Motodollar's Avatar
Chaos.
Do you mean that both front wheel bearings are different between themselves???
I noticed de bearing code 6204 in the manual, but what bearing did you try to install that you messed up the rim?
I thought about getting a 20x42x12 bearing and install it inside a 1,5mm ring. That would give me the 20x45x12 size.
Else, just importing the original ones and wait a week or so.
Thanks
Old Mar 10, 2006 | 04:45 PM
chaos321's Avatar
The manual is wrong! It is quoting a front bearing size for the 99-00 year F4. The true front bearing size is 20x45x12. Both sides! I ordered what was listed in the book to replace after powder coating and beat the $hit out of it and messed up the races on the front rim. I then rounded up the old bearings and did a cross check with Honda's numbers and this is the size I got from the Honda Service Center at Honda of America!
Taw1985
Jun 18, 2013 09:50 PM
sikiriki
F2 Tech
Aug 19, 2011 05:28 AM
berga1
Oct 11, 2009 01:36 PM
pr0jktmayhem
May 25, 2009 11:31 AM
Craigart14
Nov 30, 2008 11:20 PM
