Vibration
Old Jun 12, 2008 | 03:12 AM
Glocker23's Avatar
Default Vibration
I have a vibration issue in the front end. I don't I can def feel it when in the corners and at a higher speeds. Ideas??? Last year I had new tires put on and they were balanced. so if they were done right, that should not be it. Never had this problem before
Old Jun 12, 2008 | 11:07 AM
Ruftags's Avatar
Default RE: Vibration
Do you mean a buzzing vibration, a hopping type vibration or your bars are wiggling back and forth real fast? Can u be more specific?
Old Jun 12, 2008 | 11:34 AM
y0ukeun's Avatar
probably need to get them tires balanced again. my friend and i both had the same problem on our bikes. brand new tires on ours too. just take it back to the place u got ur tires they probably did a bad job.
Old Jun 12, 2008 | 10:09 PM
WOT's Avatar
WOT
You need to provide more info for some real help with this. I would check your chain adjustment/slack, tire pressure, rock your front forks with the brake on and listen for a clunk, put your bike up on a stand and try to move your rear wheel side to side to see if you wheel internals are f'd up. Worn tires cause more issues than you might think and also a worn drive train (chain/sprockets)
Buzzing is a different issue and could be your cam chain tensioner lifter.
Old Jun 13, 2008 | 08:07 AM
Glocker23's Avatar
Not the CCT, but it is annoying. It more of a hard vibration on the handle bars which I can alsmost hear. Really scary going hard into a lean at a good speed
Old Jun 13, 2008 | 10:01 AM
Jump1979man's Avatar
make sure your weights are still on the tire.....sometimes the stick on ones will come off. Thats why a lot of racers put tape over them.
Old Jun 13, 2008 | 10:35 AM
y0ukeun's Avatar
ORIGINAL: Jump1979man
yeah thats what happened to both me nd my friends bikes..
Old Jun 13, 2008 | 02:27 PM
Glocker23's Avatar
thought that too, but they r still there
Old Jun 13, 2008 | 09:54 PM
WOT's Avatar
WOT
Could be excessive Wheel Bearing Play, Wheel hub, or the swingarm pivot bearing is worn. Good luck!
Old Jun 13, 2008 | 09:56 PM
kneepuck oo envy's Avatar
although ive never experienced it myself, people have complained about missing or loose bar ends...other than that, id vote towards getting your front rebalanced...
jagdiver
Jun 3, 2009 04:41 PM
otr002
Feb 1, 2009 06:34 PM
vegaman81
May 10, 2007 04:36 AM
laybac
Jun 13, 2006 03:01 AM
tallassguy
May 23, 2006 10:13 PM
