Vibration
Old Jan 25, 2009 | 09:26 PM
otr002's Avatar
Default Vibration
Hey what's with the vibration in the right hand grip. My old 92 CBR was smmmmoooth and this 97 has a annoying vibration coming through the right hand grip the left is ok but it also has a vibration, although very mild. any ideas, carby balance maybe?
Rod
Old Jan 25, 2009 | 11:33 PM
slowpoke's Avatar
Default RE: Vibration
The carbs are different, but you could also check tire balance, tire pressure, loose motor mounts, and fork binding.
Old Jan 26, 2009 | 01:33 AM
mikekop's Avatar
October 2009 ROTM
and condition of drive chain and sprocket + adjustment of balancer shaft. Correct handlebar-weights?
Old Jan 26, 2009 | 03:17 AM
bluebeard's Avatar
carbie balance can cause vibration but more commonly check the items listed above>
Old Jan 26, 2009 | 03:20 AM
otr002's Avatar
ORIGINAL: CBRclassic
Gawd...vibrations can come from all the places or causes mentioned above in the guys posts .
I dunno about the carbies causing it (although , sure it could be?) ...more like balancer adjustment or chain / sprockets near there end perhaps mate ..
You did not actually say how long you have had this new ride ?
or whether the vibration has just started , or has been there all along since you got her ?
Ok just brought her last Wed and rode her back from Canberra to Brisbane (1300k's) the PO had removed the bar end weights and fitted heated grips. At around the 2 hour mark the vibration was just to much to stand so i cut the end of the grips and refitted the weights (there were two sets) i may have fitted the wrong ones???[:@] the vib was reduced to a bearable level and that's how it stayed. So the main chain is a little on the slack side so i'll tighten it tomorrow, the front end looks/feels/seems ok and the engine is sweet and quite> So i was a little mystified, as i had checked the usual spots...so it's over the the "Knowledge"[:-][IMG]/image]
Old Jan 26, 2009 | 03:24 AM
karlo's Avatar
Nice colour scheme, I put Gel grips on mine.[sm=smiley20.gif]
Old Jan 26, 2009 | 03:29 AM
otr002's Avatar
Hey Karlo is your carry rack a Honda one or aftermarket?? You are so right about the colour scheme, and as for grips, yep I'll be doing some looking around and will fit something a little more comfortable Oh almost forgot, how do you find the touring screen?
Rod
Old Jan 31, 2009 | 03:26 AM
otr002's Avatar
Spot on mate! tightened the chain and voila no more vibs, oh and i fitted new gel grips to, just to be on the safe side.
Rod
Old Jan 31, 2009 | 10:07 AM
sawnee's Avatar
Another satisfied customer
