Tranny dogs grinding.
Old Mar 31, 2019 | 10:06 AM
chasemcclary's Avatar
Originally Posted by CaBaRet
Then hopefully the right idle speed should sort it out
I hope that and a tighter clutch if not idk because it can't be dogs from what I have read it it doesn't pop out of gear
Old Apr 3, 2019 | 10:11 PM
sjona2011's Avatar
Your idle speed has nothing to do with shifting at high rpms.... Or shifting in general for that matter. Make sure your clutch is adjusted properly and try again. If it still does it, then it'll either be a shift fork, or shift drum issue. Replacement of those is annoying, but not too difficult to do, requires you to drop the oil pan and remove your clutch.
Old Apr 3, 2019 | 10:46 PM
I haven't been able to ride though i did need to make the clutch a bit looser and i put the idle speed down so im hoping its good after that.
Old Apr 4, 2019 | 12:16 AM
CaBaRet's Avatar
Hi , we were talking about preloading the shift for clutchless changing up , so dont really need any excess engine rpm when rolling off the throttle
Old Apr 4, 2019 | 05:15 PM
sjona2011's Avatar
Hello, the OP is about shifting at high rpm, he also stated he's not clutch less shifting from first to second...so I'm kind of lost as to what you're on about.
Old Apr 4, 2019 | 11:29 PM
CaBaRet's Avatar
Originally Posted by chasemcclary
My f4i tends to grind from first to second at high rpm I don't think it's the clutch and lower rpms are smooth as butter. I'm running rotella t6 10w 40 full synthetic and the bike only has 5000 miles. It doesn't do it every time just when I'm really on it. When I preload the shifter it reduces the grinding but doesn't get rid of it. Any ideas on what I can do.
Here matey ,he says about preloading the shifter for a up gear change ,and i said always use the clutch for 1st to 2nd gear and clutchless the rest, might of assumed he was attempting clutchless from 1 to 2
Michaud85
Aug 6, 2012 10:54 AM
wnitzf3
Sep 13, 2010 09:19 AM
pjrocco
Aug 20, 2009 06:44 PM
Dennis in NH
May 12, 2009 08:55 PM
toolfan524
Sep 5, 2006 02:03 PM
