Rough shift from first to second gear
Old May 9, 2009 | 11:06 AM
Dennis in NH's Avatar
Default Rough shift from first to second gear
Hi all,
1999 CBR 600 F4, about 23K miles (3K of them being me); new clutch cable. I feel like the bike doesn't shift from first to second gear as easily/cleanly as it does between the other gears. Is this typical? any tips on how to alleviate this? maybe shift into second only at moderate RPMs and not at too low RPMs.
I'm using Honda dyno oil (put it in about 2K miles ago). Maybe some Amsoil 10w-40?
I'm wondering if there's an easy way to ascertain the level of clutch wear. Is it easy to just open up the clutch housing and take a peak (without having to drain the oil and create a mess and/or any risk of damaging stuff if it's my first time)?
Wet road up here and in Southern NH and raining off/on but good enough for a ride (with rain pants on).
Thanks,
Dennis
Old May 10, 2009 | 04:37 PM
yog182's Avatar
Are you shifting at a high RPM or a low RPM with the bike? Try it both ways and see if there is a difference.
Old May 10, 2009 | 06:27 PM
CB750's Avatar
Kinda clunky? Are you a new rider? I've noticed that on all my bikes, and I figure it's because you have to pass through neutral to get to second. Try pulling in the clutch and pausing half a second before you kick it into 2nd. Or you can try leaving the clutch out, and putting pressure on the shift lever, Back off the throttle a bit and it'll shift for you. Sometimes that's smoother.
Old May 10, 2009 | 08:23 PM
loyboy10's Avatar
yea if you check out the reviews and tests the only 2 complaints on the f4 was vibration and 1st to 2nd gear shift
Old May 11, 2009 | 03:43 PM
If I shift at higher RPM the shift is smother. I'll try to raise the revs a little more when I shift from now on.
Thanks for the responses.
Dennis
Old May 12, 2009 | 05:21 PM
ajlong's Avatar
Don't lazt shift it, shift fast, that'll help.
Old May 12, 2009 | 08:55 PM
That's what I'm finding. I sometimes want to baby the clutch and shifter only to find that this bike wants me to really ride it and it responds by having smoother shifts.
Such a different personality from my cruiser (Vstar 1300).
Dennis
Trent Dog
Jul 9, 2012 06:32 PM
Tort93f2
Apr 13, 2012 12:18 PM
TAT2D
Mar 8, 2008 09:20 PM
cleansho93
Aug 19, 2007 03:49 PM
Blair
Feb 15, 2007 11:33 AM
