Taper Roller Torque Setting
Old Apr 6, 2021 | 01:28 PM
roundyuk's Avatar
Default Taper Roller Torque Setting
Does anyone have a good starting point for the torque on the bearing adjustment nut for taper rollers on the head bearings?
Thanks!
Old Apr 6, 2021 | 07:22 PM
LightningAge's Avatar
Hi
I'm looking at page 1-15 of the CBR600F4i 01-03 service manual and it says:
- Steering bearing adjusting nut: QTY 1, Thread Dia 26mm, Torque 25Nm
- Steering bearing adjusting nut lock nut: QTY 1, Thread Dia 26mm, Torque N/A
- Steering stem nut: QTY 1, Thread 24mm, Torque 103Nm
Details on how to do are provided on pages 13-29 --> 13-33 of the service manual.
Old Apr 7, 2021 | 06:50 AM
roundyuk's Avatar
Originally Posted by LightningAge
Hi
Thanks, I have the manual but I believe that torque setting is based on the original factory bearings, not taper rollers....?
Old Apr 7, 2021 | 02:29 PM
I think for tapered bearings, you'd have to go with recommendations from some place like All *****.
Old Apr 9, 2021 | 01:48 PM
roundyuk's Avatar
Ended up setting by feel, but then found a kgf spec for preload in the manual, just been out and set closer to that...
tjescrazy
Jun 21, 2014 09:13 AM
cBrentb
Dec 13, 2011 06:56 PM
animalmother
Sep 3, 2009 07:13 AM
Shadow
May 30, 2008 09:27 AM
fafar59
May 13, 2006 08:31 PM
