Tank Question
Old Jul 10, 2007 | 10:47 PM
CBRtokyo's Avatar
Default Tank Question
will any F4i tank fit on an 02 F4i? or does it have to be an 02
Old Jul 10, 2007 | 10:53 PM
woodyracing's Avatar
Default RE: Tank Question
definitely any 01-03 tank will work, not sure about 04+ though since they have different subframes
Old Jul 10, 2007 | 11:10 PM
JDubF4i520's Avatar
people are always doing the dual tail conversion with the different subframe on there 04-06 so 04-06 tanks will definatly work
Old Jul 10, 2007 | 11:11 PM
EPNF4i's Avatar
04 to 06 will work as well. I have a sub frame from an 03 on my 06 What happened to your tank, if you don't mind my asking? Hope everything is ok.
Old Jul 11, 2007 | 03:28 AM
CBRtokyo's Avatar
Oh yeah everything is ok, A friend of mine just bought a 02 F4i pretty much in shambles, He got it pretty much all together, got to the tank and it dosnt fit. I know its a F4i tank cuz its the same as mine. Its hard to explain but if i post some pics does anyone think they may be able to help us out. Im not sure if its just missing a certain bracket or a mounting piece or what. We are tank swappin this weekend but that seems like a waste of time since any F4i tank will fit any F4i frame. Ill try to get some pics up. Thanks
Old Jul 11, 2007 | 06:40 AM
alekinci's Avatar
yes, i looked over the manuals and from f4 (99-00) and all the f4i should be fine.
Old Jul 11, 2007 | 08:20 AM
CBRtokyo's Avatar
Thank you very much!
Old Jul 11, 2007 | 09:13 AM
JDubF4i520's Avatar
cbrtokyoi sorta came across the same problem as you when i was replacing my tank. what happened with mine was i put the 2 botton bolts in first and i could get the top 2 bolts to even closely line up i was freaking out. then i put the top 2 bolts in first and the bottom 2 went in just fine
Old Jul 11, 2007 | 06:22 PM
smak_blaze's Avatar
ORIGINAL: alekinci
I thought the fuel pumpson the f4's were different from the f4i's, so the tanks dont work from an f4 on a f4i.Wrong or right?
odano1988
Sep 15, 2015 07:26 AM
ICEmonky
Feb 14, 2011 03:13 PM
Turbulenz
Jan 5, 2010 05:20 PM
mikebike
Sep 11, 2008 07:43 PM
TBone
Mar 5, 2005 02:54 PM
