Gas tank question
Old Sep 11, 2008 | 01:53 PM
mikebike's Avatar
Default Gas tank question
I have to replace my gas tank. How hard is it to swich out the fuel pump. Is it just unplug and unbolt. Would I have to replace the gasket or can I use the same one. Anyone done this? I have a new tank coming.
thanks
Old Sep 11, 2008 | 02:05 PM
letsride's Avatar
Default RE: Gas tank question
it's not that hard,but I suggest replacing the gasket.If you install the old one and it leaks then you have to do it all over again.ake sure the gasket is seated properly.
Old Sep 11, 2008 | 04:24 PM
Hcstreetriding's Avatar
na piece of cake, the gasket is rubber you dont have to change it, i switched mine out a few times before i got the tank i wanted and it is leak free.
Old Sep 11, 2008 | 05:30 PM
TK954RR's Avatar
Jan 2009 ROTM
Yea its pretty easy. you can look at your gasket and check condition. Like both above said a new gasket is a sure way to guarantee no leaks, but your old one will probably be fine. Judgement call on your part.
Old Sep 11, 2008 | 07:43 PM
mikebike's Avatar
good I thought it would be easy. Thanks
odano1988
Sep 15, 2015 07:26 AM
sean1037xx
Jun 19, 2011 06:26 PM
ICEmonky
Feb 14, 2011 03:13 PM
Turbulenz
Jan 5, 2010 05:20 PM
TBone
Mar 5, 2005 02:54 PM
