Suspension setting help
Old Sep 30, 2007 | 06:28 PM
sharker98's Avatar
Default Suspension setting help
Got back from a good ride a while ago, 6 of us... Anyhow... when going into corners hard or bumps on decel, the bike is a little floaty, seems the dampening needs to be dialed up a bit...
The bike is stock, 06 F4i, I am about 200 pounds...
Any ideas on a decent setting to try out front and rear?
I ride the bike pretty hard and wheelie frequently as well.
Thanks in advance.
Old Sep 30, 2007 | 06:31 PM
Ace_f4i's Avatar
Default RE: Suspension setting help
did you adjust the preload for your weight? i'd look into getting stiffer springs i fyou're really worried about how the bike handles.
Old Sep 30, 2007 | 07:20 PM
.HoUnD.'s Avatar
ORIGINAL: sharker98
Thanks in advance.
I'm also 200 lbs.. 06 f4i. These will get you close till you can get it set up by a pro.
Front Pre-load = 3.5 lines showing
Rear Pre-load = 5 or 6 I prefer 6
All Damping front and rear = 1/2 turn out from full stiff (go all the way till it seats then back off 1/2 turn)
Old Sep 30, 2007 | 07:55 PM
sharker98's Avatar
Hound....
Thanks, That is exactly what I was hoping for....
BTW How did you go about your split seat conversion, parts sources, costs, etc... I may be doing one soon.
Old Sep 30, 2007 | 08:22 PM
.HoUnD.'s Avatar
Lots of research and money =) Tons of threads around here.
On your settings.. If it feels to harsh going over bumps try reducing each a .25 turn at a time. I would start with the compression damping then rebound.
For me anymore then .75 out on any one of the damping especially the rear and it starts feeling vague and wallowy.
Anyway goodluck.
beaujarle
Mar 24, 2008 09:11 PM
Jaybird180
Oct 10, 2007 10:16 AM
mirks
Apr 13, 2006 03:41 AM
Supersteve911
Jan 3, 2006 10:25 PM
Turboedsupe
Sep 20, 2005 08:02 AM
