Sudden hard knocking, dies at idle. Advice?
#41
with proper research you can find everything you need to do the job more affordable than you would believe...
you have to search all your option amazon ebay craigslist babbits online..
you can find amazing deals
a engine can be built affordable... BUT it depend on the type of person you are
see i am the person that will crack the engine open and check the bearings seals clean the head/valves and pistons on the new engine... so i would be opening a engine up no matter what.
so when i spun a bearing on my f4i i went ahead and performed a rebuild ...
currently in the final stages of the build and it is stressful as hell. thinking did i torque this did i torque that .. did i take that measurement right... double triple checking things....
so what kind of person are you ???? you going to just drop the engine in or you going to open it up???? if your not going to open the new one up then you might as well buy a engine.... cause if you would take the time on the new one why not spend it on the old one.. my frame of mind
take the time to research the parts and what kind of downtime are you willing to experience....
so me personally i went to rebuild what i have...
you buy the engine get it over with i just think you could find a better price
on the engine
let me find the thread i think there is a guy on here still selling one i will edit it if i find it
here you go https://cbrforum.com/forum/f4i-wante...needed-143504/........ guy post he had one for sale from AL he doesn't have the minimum post needed but i contacted him nice guy affordable price worth checking with him.... talk to him see what he says i don't really remember the conversation in to much detail
but hey it might make you happy...good luck
on the engine
#42
Update!
I ended up ordering a different motor from eBay.
The first one I linked was $800 for a ~3k mi motor, but when I called they knocked it down to 600 free shipping for no reason... it was shady.
I found another engine from a 2005 F4i with 8.4k mi for $699 w/ free shipping. Track tested before packaged. I spent the few weeks inspecting, mounting, studying the insane hoses going everywhere. I finally got it all together 2 days ago. Starter wouldn't turn over & fuel pump wouldn't prime. Found a loose neutral switch and kickstand sensor, plugged those in and it started churning. Took me a few days to remember the schematic for my USB ignition key but I finally got it together. Plugged the usb in, and voila! fuel pump primed, and after 15 sec of just turning over it started catching a spark. It was a low dying idle until I realized my gas tank was leaky and wasn't priming fully. So repositioned the tank, re-primed, and she fired up strong!!! I was very nervous about the engine swap because when I turned the crank by hand it seemed too smooth, like it had bad compression. But once it warmed up and I gave it some throttle I'm not worried anymore. I then got super excited, fixed up a wiring problem I had, centered the engine properly (aka. a pole for leverage and needle nose for the adjuster mounts xD), and got the chain on the sprocket. So ecstatic I went to roll start it (dead battery). Annnd nothing happened. Tried to jump it, now the fuel pump wont prime which means it's my USB key. I probably shorted it when it touched it's bare wires to my fuel tank and sparks flew everywhere. So, a very exciting climactic then anti-climactic frustrating day. BUT, she's alive! And I couldn't be happier than this nightmare will soon be over. Just one more stop by radioshack to get the ignition squared away. Thanks for all of your help everyone, even though my old motor is just sitting in my garage now, I learned a phenomenal amount about the engine and definitely have a new respect for it. It's going to feel so strange riding after 4+ months.. ahh!!
#45
Haha thanks! I really don't know, I thought about selling it for parts. I guess I could do that on here. I know for sure the cylinders are in great condition, and it had great power to it. It seems a shame to let it sit around if someone could use the top half. Haven't put much thought into it.
#47
#48
Hurricane9
08-09-2015 09:14 AM
johnk16
07-08-2013 03:17 AM
