F4 2000 Clutch slipping hard every gear all of a sudden *help*
Old Aug 8, 2015 | 09:56 PM
Hurricane9's Avatar
Default F4 2000 Clutch slipping hard every gear all of a sudden *help*
Bought this bike a week ago and the clutch was great then all of a sudden it started slipping
The guy had the adjuster nut on the lever as tight as possible there was zero free play. So I replaced the clutch cable and removed the adjuster nut at the lever to have free play clutch still slips
Adjusted the lower clutch also
It only has 12k on it
Old Aug 8, 2015 | 10:07 PM
74demon's Avatar
What kind of oil is in it?
You may need to replace the clutch....
Old Aug 8, 2015 | 10:21 PM
Hurricane9's Avatar
I don't know
Is this a good clutch kit
http://www.amazon.com/gp/aw/d/B000GR...=AY6B10HJNSJYH
Also I think it may be cable related
Old Aug 8, 2015 | 10:24 PM
Hurricane9's Avatar
Also I the owner the cable very tight
There was no room to loosen it
Old Aug 9, 2015 | 09:14 AM
74demon's Avatar
The cable only releases the clutch so you can shift. To loose and you won't be able to change gears, too tight and it is constantly half released and will feel like its slipping.
Slipping clutches are caused by the cable being tight, worn/damaged clutch parts, and prolonged use of incorrect motor oil.
The cable primary adjustment is on the lever at the motor. Get that close, then fine tune it at the bars.
burbleburble
Oct 3, 2013 08:29 PM
jacksla3
Mar 13, 2013 08:55 PM
Globaljezza
Jan 27, 2011 08:22 AM
kona200244041
Mar 31, 2008 09:31 PM
