bike dies after hard riding
i was riding my bike for about 45 min. got to the highway and starting riding a little harder than normal. i stop at a trafic light and my bike idle normal no problem. decided to go a little faster. after i got off this one exit and my bike started idling wierd so i put in reserve gas and it run fine until it started shuting off when in neutral after going fast.
i got a cbr f2 does reserve limits the amount of gas your bike gets? or what? i dont get it?
you've got less than a half gallon on reserve on these bikes - which means if you're riding hard, you might only have 8-10 miles on reserve. Reserve is "get to a gas station" mode, not "keep on riding".
Your whole description sounds exactly like when I'm running low on fuel and have had to switch to reserve.
Use the odometer as an indicator of how much you've run on that tank - 4 gallon tank = 3.6 gallons on "on" position, and .4gal on reserve. @ 34-38mpg (spirited and city driving) means you should get 120-135miles to a tank before hitting reserve. I've stretched to 160miles on a easy cruising day without a ton of high revving moments.
one other thing - if your float levels are set incorrectly, it is possible you may be running the bike hard enough to where the carbs are drinking faster than the floats are letting fuel in.
i understand now. sorry if i sound like a retard.new at carbs my really first bike was 07 gsxr 600 so cause of money situation and riding is addiction i found a new bike that satisfies my riding. but i still have a lot to learn on this bike. and how to ride it.
thank you for all the help.
