Stuck key....?
Old Aug 19, 2010 | 01:56 AM
nickp123's Avatar
Default Stuck key....?
I had to order a new ignition and gas cap so i got one off ebay and tested the key in the ignition to make sure it turned then tried it in the gas cap since the keyhole seemed to be a little worn around the outside....the key went in and turned now it wont turn back and cant be pulled out. suggestions please?
Old Aug 19, 2010 | 06:04 AM
usetheffours's Avatar
you have to push on the rubber ring under the gas cap (to simulate it being closed) or the key will not come out
Old Aug 19, 2010 | 10:57 AM
nickp123's Avatar
i knew that
Old Aug 19, 2010 | 11:18 AM
Xander F4i's Avatar
close the cap and push down...i know lately my key has been turning very slowly when i close it after filling my tank. not sure what is up with that..
Old Aug 19, 2010 | 03:06 PM
As with most things, lube will help The girlfriend's gas cap was like that when she got it. I put some (chain lube I think) on the metal ring underneath and the 2 latches that lock it to the tank. So now everything slides in and out smoothly
Old Aug 19, 2010 | 03:10 PM
__Z__'s Avatar
April 2011 Ride of the Month
Wait u were referring to a motorcycle correct?
Old Aug 19, 2010 | 03:39 PM
PlayfulGod's Avatar
wd-4o it
Old Aug 20, 2010 | 01:32 AM
nickp123's Avatar
yeah ill do that tomorrow its still a little sticky and requires a decent amount of effort...or at least more effort than should be required to turn a key.
scorpionvmu
Feb 23, 2011 05:23 PM
live4liftin
Mar 4, 2010 06:30 PM
bikerbrooks
Apr 29, 2008 03:39 PM
Kikepiz
Apr 23, 2008 01:38 PM
