Starting Problems
03 CBR F4I. Here is what i have done, i got the battery tested it is fine. i cant start the bike when you push the starter it just clicks. i can get it started if i run and dump the clutch it will start but it just seem as if it isn't getting enough juice. which leads me to the stator. i will take any advice on a diagnosis or any other info thanks.
my friend had the same exact problem with his older suzuki gsxr..the bike was a piece of **** and the battery had plenty of charge going through it but would still die and he had to either push start it like you, or spray some methane onto the radiator and then it'll start. not much use my reply, but you could always carry around an extra methane sprayer
