starting issue
Old Dec 31, 2010 | 09:40 AM
ya2save's Avatar
Default starting issue
I have an 03 F4I with 6200 miles that starts up no problem when its cold but after the bike warms up it gives me a hard time every time I try to start it. Does anyone have any ideas as to why this is happening?
Old Jan 1, 2011 | 04:12 AM
LasVegasHarley's Avatar
Check your fuel pressure regulator.
It is located under the fuel tank on the fuel rail. It has a vacuum line attached to it (it's the skinny rubber hose), pull the vacuum line, if it is dry it is good but if it's wet with fuel then you need a new one.
Old Apr 12, 2011 | 12:09 PM
kash's Avatar
my bike started right, I let it warmed up a bit. when I cranked the throttle it shuts off & it will not start back up. You can hear the pump & it will turn over but it will not fire. I replaced the plugs. It starts right away but again when I crank the throttle it shuts off & will not start again. Anybody has any suggestion?
Old Apr 12, 2011 | 09:12 PM
ska8terpunk84's Avatar
I am in a very similar situation as you. I pulled the vacuum line off my fuel pressure regulator and it appears to be dry. I recently did a fuel flow test and the service manual states that it needs to flow about 6.4 oz in ten seconds and my bike was only doing half of that. Right now I am looking into the fuel filter to see if that will do the trick. Trying doing a fuel flow test and see what you get.
georx
Jul 6, 2010 01:12 AM
derrickvaw113
Mar 21, 2010 04:06 PM
lilpakastain239
May 29, 2009 07:38 PM
Tclipse989gst
Dec 15, 2007 07:16 PM
cottlefish
Sep 18, 2006 04:22 AM
