Speedometer problem
Old Jun 15, 2009 | 09:39 PM
Blove1991's Avatar
Default Speedometer problem
For some odd reason when I start the bike, the speedometer is reading like 7mph and when you rev the bike up and pull some rpms the MPH also goes up. Everything else is fine. Except the horn doesn't work now.
Anyone have an idea?
This started AFTER we switched the bent frame for the new one. I can't imagine something is hooked up wrong considering all the plug-ins are different?
Old Jun 16, 2009 | 12:50 AM
Blove1991's Avatar
Anybody have an idea?
Old Jun 16, 2009 | 06:07 AM
terror rising's Avatar
What does the speedo do while riding? Do the tachometer, coolant temp, and odometer function correctly?
Old Jun 16, 2009 | 11:41 AM
DBEAU's Avatar
It seems there has to be a problem with the speed sensor.
Old Jun 16, 2009 | 06:10 PM
Blove1991's Avatar
Me < Fail
Once everything was finally put together (chain put on) it cured the problem.
Guess the front sprocket has some free play in it and spins
Old Jun 16, 2009 | 11:32 PM
Aken's Avatar
July 2008 ROTM
Originally Posted by Blove1991
Me < Fail
Yeah there's some centrifugal force or something that allows it to move even in neutral. Try putting your bike on the rear stand and then rev it up - the rear wheel will spin a bit.
Baooo
Jun 7, 2009 10:37 PM
allenpa5
Aug 14, 2007 01:11 AM
jthompson084
Dec 23, 2006 02:50 PM
ddaren
Oct 30, 2006 07:55 PM
HAVOC
Aug 18, 2006 03:03 PM
