Sixth Gear Modification ??
Old Apr 6, 2009 | 02:20 PM
TURTLE's Avatar
Default Sixth Gear Modification ??
I've been struggling with the idea of -1+2 sprocket change for almost a year now but I do alot of highway riding and I don't want to give up my cruising MPG. Has anyone heard of or had experience with changing the sprockets and the Sixth gear in the tranny to counter the effects on top end? I've tried but I can't seem to find anyone who sells the gears for the tranny itself. Any thoughts would be appreciated.
Old Apr 6, 2009 | 02:31 PM
RojerLockless's Avatar
so you want to change the sprockets.. and then change the tranny for higher top gears?
wouldnt that defeat the reason for the sprockets in the first place?
-1 +2 isint that HUGE of a change. you will notice the speed for sure but your top end should only suffer by about 1.5k rpm's
Old Apr 6, 2009 | 02:38 PM
TURTLE's Avatar
My goal was to do the conversion for the lower gearing in 1 thru 5 but keep the same or close to the same 6th gear ratio.
Old Apr 6, 2009 | 07:22 PM
Rotory2F4i's Avatar
Its not really that bad. Instead of 50mpg, your gonna get 49 (example) Youll spend more money trying to change 6th gear than a new chain/sprockets.
Old Apr 6, 2009 | 07:25 PM
Aken's Avatar
July 2008 ROTM
Yeah, MPG will only be slightly affected. I wouldn't worry about 6th gear.
Old Apr 6, 2009 | 09:43 PM
Luck Runs Out...'s Avatar
The reason you can't find a set of 6th gear gears is because they don't exist outside a Honda dealership.
monster758
May 25, 2011 01:25 AM
Michael S
May 18, 2009 09:12 PM
james007torres24
Oct 14, 2006 07:42 AM
