Seafoam opinions
Old Jun 29, 2017 | 09:51 PM
Tsouth937's Avatar
Default Seafoam opinions
So was gonna throw seafoam in my bike. Thought I'd ask anyone ever do this. Did you put it in gas tank or oil or vacuum house what was your best out come
Old Jun 29, 2017 | 09:57 PM
rfesu's Avatar
go for it.
a bit of seafoam or other decarbonizer in the fuel will clean carbon and bunk gas deposits naturally without doing any damage.
if you have performance problems resulting from carbon buildup, it'll make a difference, otherwise it will do nothing.
seafoam compresses past the rings as it doesn't want to burn off, so it will contaminate your oil sump a bit, so do this before an oil change.
results? i've had it DOUBLE the power on a grandma car that never went over 2,000rpm in its life. i've had it bring engines that had excess carbon buildup so bad that they would barely run and their valves were hung open back to near-zero leakdown. on a well maintained engine that was driven like it's supposed to be, i've noted zero improvement.
Old Jun 29, 2017 | 10:18 PM
And I had it seize the engine of a pretty decent weed eater after about 30 seconds.
It won't clean varnjsh or other gas related buildup out of your carbs. But like previously said, it will ckean the carbon.
Old Jun 29, 2017 | 10:21 PM
rfesu's Avatar
you poured in too much, man. way too much. i used to work at a service shop for weedeaters where we'd keep some in our service fuel, it never caused a problem.
Old Jun 29, 2017 | 10:25 PM
no sir. i followed the intructions to the letter. I even used a measuring spoon. The engine simply did not like it.
k.600f4i
Mar 21, 2008 05:12 AM
95Cbr6
Mar 11, 2008 08:15 PM
ffingers
Jan 13, 2008 10:22 AM
ampfp
Feb 7, 2007 04:20 PM
