Using SeaFoam in a bikes tank?
Old Mar 10, 2008 | 10:19 PM
95Cbr6's Avatar
Default Using SeaFoam in a bikes tank?
I have never used SeaFoam before and i'm thinking about running it through my tank. I heard that you use 1 ounce of SeaFoam for every gallon of fuel. I have a 4.2 gallon tank so i'm just gonna use 4 ounces. my question is, do you have to run the tank dry before it stops smoking? What are the procedures for using this product in the gas tank?
Old Mar 10, 2008 | 10:52 PM
TennesseeCBRF2's Avatar
Default RE: Using SeaFoam in a bikes tank?
1 oz of seafoam per gallon is correct. Your fuel system would have to be nasty for that concentration to cause much smoking, however. Just pour it in, and ride like normal. As far as I know there is no time frame you need to burn it through.
I would run the seafoam tank almost to empty though before refilling with fuel, as that will alter the concentration.
Old Mar 11, 2008 | 04:53 AM
fishfryer527's Avatar
I use it beforeeach oil change in case any kind of 'stuff' makes its way into the oil. I don't worry about running it untill dry, just till the reserve comes on. I have not noticed any smoke or smell or anything not normal.
Old Mar 11, 2008 | 08:18 AM
md8181's Avatar
What is sea foam and what is it for?
Old Mar 11, 2008 | 09:18 AM
SchiraF4I's Avatar
http://www.seafoamsales.com/motorTuneUpConsumer.htm
Mine smoked towards the end of the tank just add some more gas to mix it and it should stop.
Old Mar 11, 2008 | 12:33 PM
KidCr3nshaw's Avatar
Seafoam is one of those miracle serums. Works in everything. You should just dunk your engine in a tub full ofSeafoam and let it run.
Okay, that might be overkill but still...
Old Mar 11, 2008 | 08:15 PM
MikeInCtown's Avatar
If you only add 1oz per gallon you probably won't see any smoking, but rather notice a different smell from the tailpipe. If you add more it may smoke, but it will clean better.
For my bike I just add Lucas Fuel system treatment in the small bottle. One bottle is supposed to do up to 16 gallons, but I dump the whole thing in. Smells a little bit but no smoke. Has worked better for me than seafoam. (but Seafoam has worked better in my truck than the Lucas)
dad0507
Sep 3, 2014 06:59 AM
ZBike
Apr 7, 2012 11:51 AM
scorpionvmu
Nov 21, 2011 12:29 PM
pvtdonuts
Jan 15, 2010 09:46 PM
