Seafoam opinions
go for it.
a bit of seafoam or other decarbonizer in the fuel will clean carbon and bunk gas deposits naturally without doing any damage.
if you have performance problems resulting from carbon buildup, it'll make a difference, otherwise it will do nothing.
seafoam compresses past the rings as it doesn't want to burn off, so it will contaminate your oil sump a bit, so do this before an oil change.
results? i've had it DOUBLE the power on a grandma car that never went over 2,000rpm in its life. i've had it bring engines that had excess carbon buildup so bad that they would barely run and their valves were hung open back to near-zero leakdown. on a well maintained engine that was driven like it's supposed to be, i've noted zero improvement.
Cerberus XJR
02-21-2009 05:38 PM
ffingers
01-13-2008 10:22 AM
