RPM's not snapping back quickly - NEED HELP PLEASE
Old Sep 26, 2008 | 11:21 PM
MR2turbo4evr's Avatar
Default RPM's not snapping back quickly - NEED HELP PLEASE
I tried to do a throttle body adjustment with a Motion Pro SyncPro tool. I followed the instructions and calibrated the machine. I then connected all 4 vacuum hoses from the bike to the SyncPro. Of course the reading was out of whack because the throttle body has probably never been adjusted. Well I tried adjusting it so the bars would all line up but the reading in cylinder 3 was way to high. I screwed the adjustment screw in till it couldn't go any further and made the reading a bit better. I had trouble keeping the idle at 1300rpm, etc, so I gave up, connected all hoses again, put all the fairing pieces back together and called it a day. Well after taking the bike for a ride I noticed that the rpm's don't snap back as quickly anymore. I can sit there and rev the engine till about 3000rpm and it will stay there for a short period of time and get back to idle....but a lot slower than before.
What could've caused this? I understand that the adjustments I made were to control how much fuel each cylinder gets.....I don't think it should cause the problem I have, but I could be wrong.
Anybody else have the same problem. Please help! Thanks in advance.
Old Sep 27, 2008 | 12:51 AM
Xuracing's Avatar
Default RE: RPM's not snapping back quickly - NEED HELP PLEASE
Is your throttle cable sticking?
Old Sep 27, 2008 | 10:44 AM
letsride's Avatar
Sounds like you need to adjust your throttle cables.
Old Sep 27, 2008 | 05:08 PM
LiMe_GrEeN_MaChInE's Avatar
cable,,, if it was a dirt bike i would say the slide has some sand or dirt and is hanging the slide
Old Sep 27, 2008 | 05:22 PM
DBEAU's Avatar
does this adjusting throttle bodies really help anything?
abs929cbrrr
Aug 27, 2008 07:03 PM
Honsuheikki
Apr 30, 2008 12:34 AM
ciupe
Apr 21, 2008 09:48 PM
1badeg
Apr 10, 2007 05:51 PM
mervyn
Jan 24, 2007 08:54 AM
