RK 520 conversion
Old May 17, 2007 | 11:22 AM
speedra500's Avatar
Default RE: RK 520 conversion
the type of chain does not affect gear ratio
Old May 17, 2007 | 12:00 PM
hondajunkie's Avatar
Official Welcome Crew Junkie
RK 520 chain conversion using Vortex -1/+2
Waayy better accell, but like was said earlier, speedo is waayy too optmistic!
Old May 17, 2007 | 01:12 PM
Tahoe SC's Avatar
a 520 won't give you anything noticeable around town...if you take that to the track then yes.
what most people do is go with 520 conversion with gear change and then say...WOW...520 is the schiznit...no dude...you're feeling the gear swap.
stick with stock and swap gears.
now...this may hurt some of you but i have to...from my experience, RK's aren't very good (ok actually i think they suck)...DID is the way to go.
Old May 17, 2007 | 02:54 PM
2003F4iDude's Avatar
I love my Rk 520 with -1 +2 with a teflon coated rear sprocket, and i purchased a Speedo Healer to calibrate my speedometer so now its dead nuts acurate, both took some time to research and install but it was all worth it. SpeedoHealer.com is where i got the speedo mod and SumOfAllParts.net is where i got my 520 conversion.
Old May 17, 2007 | 03:23 PM
alexr40's Avatar
rk520 chain with -1 +2 sprockets here
works like a charm.. very fast acceleration
Old May 17, 2007 | 08:36 PM
Stephens's Avatar
I have not had any issues with my RK or Vortex sprockets. Works great for me.
Old May 19, 2007 | 01:40 AM
f4iguy8804's Avatar
Expecting the kit to come in tomorrow. Do I need a rear stand for the install? I know it is cut to length but do I need any other specialty tools to put it on? Thanks.
Old May 19, 2007 | 02:15 AM
crunkchris's Avatar
i have the 525 with -1 +4 she stands up in 4th, i also have +2 that i can change out to if i go on any longer trips, oh and as far as the speedo problem get a speedo healer and problem solved
Stephens's Avatar
Yah you will need a stand to take the rear wheel off. The kit should be already set to fit. You will need a chain breaker to take off the old chain, and a chain press to put the new one one. Ebay you can find them cheap.
Old May 19, 2007 | 11:47 AM
f4iguy8804's Avatar
Thanks a lot.
DopeBoy239
Jun 26, 2010 12:06 PM
bammerman
May 27, 2010 04:40 PM
chuckb
Apr 30, 2007 08:52 PM
transamlt1man
Jul 19, 2006 09:47 PM
steve00ses
Jul 17, 2006 04:11 PM
