520 Conversion? yes or no
Old Jul 16, 2006 | 03:05 AM
transamlt1man's Avatar
Default 520 Conversion? yes or no
Say you have a 600 bike and it needs new sprockets and chain. Do you switch to a 520? (maybe this will help me deside)
Old Jul 16, 2006 | 04:01 AM
CBRCorey's Avatar
Default RE: 520 Conversion? yes or no
I'm not sure what a 520 conversion would be like. I'm 1 down in the front and I'd like to go bigger in the back but I would be miserable on the freeway because I'm already at a high rpm just doing 10 mph over, I can't imagine making it worse.
Old Jul 16, 2006 | 12:03 PM
Is has nothing to do with the gearing is it just a smaller chain (which means less weight and more power)
Old Jul 16, 2006 | 08:41 PM
FordFrenzy97's Avatar
520 is just a lighter chain.
Old Jul 16, 2006 | 11:26 PM
woodyracing's Avatar
if you've got to change the chain and sprockets anyway there really isn't a reason to not change to 520
Old Jul 17, 2006 | 12:27 AM
Well i am sure they put a 525 chain on there for a reason. Why would they spend the extra money on a bigger chain when it doesn't need it?
Old Jul 17, 2006 | 01:36 AM
HighRevver's Avatar
Well you obviously can't go wrong with stock, those guys know what they are doing so unless you want the front end up easier.
Old Jul 17, 2006 | 02:11 AM
CBRCorey's Avatar
Yah I feel dumb considering I just went through this a couple days ago.
Anyways, stick with stock. If you wan't to shave a pound off just go to the bathroom before you ride.
Old Jul 17, 2006 | 04:37 AM
ejohn's Avatar
520 chains are great. less spun weight, you will notice faster pickup, these chains are rated at something like 9000 lbs test so I don't think your going to break them with a 600cc bike. helps you slow down before corners.
Old Jul 17, 2006 | 05:45 AM
the ONLY benefit a 525 chain has over a 520 is strength and your NOT going to break a 520 chain with a 600
the factory AMA teams use 520 chains on their 600s that make 140+ HP so your 100-105 HP bike isn't gonna break it
