Reserve Indicator
Old Apr 18, 2010 | 07:13 PM
Twenty's Avatar
Default Reserve Indicator
I did try and search before posting. I have a 2001 F4i. When I turn the key and the display does it's thing, you hear the injectors etc, the fuel reserve light DOES show up where it should, as it shows in the manual. However, it doesn't show up when i'm actually low on gas. I ran it till it died on me; no reserve light ever came on. I checked the manual and couldn't come up with much. I believe my fuel reserve sensor may be bad. I can usually calculate how much gas I have by how many miles i've driven and how fast. But that's getting a little old. Having it fixed would be supreme. If anyone knows anything about this, some input would be greatly appreciated. Thanks in advance.
Old Apr 18, 2010 | 07:25 PM
dyracuse's Avatar
check for a kinked line first, mine "ran out of gas" because the vent line was almost completely closed on itself, it ran until it had about a gallon and a quarter, then the vent was too closed for the pressure of the fuel in the tank.
Old Apr 18, 2010 | 07:28 PM
Twenty's Avatar
That actually sounds like it could be the problem, I'm gonna have to look into that asap. Thanks for the input.
Old Apr 19, 2010 | 01:45 AM
RojerLockless's Avatar
let us know if that fixes it, I've never heard of this issue with an f4i
Old Apr 19, 2010 | 04:15 AM
quben42's Avatar
same thing happened to me im gonna take a look in the morning
Old Apr 19, 2010 | 06:41 AM
Seafordguy's Avatar
Be sure to reset your odometer when you fill up and then head for a fuel station around 160 miles or so...
I set mine in addition to my reserve light for just this instance.
Nybendu123
Feb 12, 2015 03:26 PM
Nybendu123
Apr 25, 2011 05:30 PM
Mstngdrew232
Sep 7, 2008 04:35 PM
jimmy_gr
Dec 15, 2005 03:53 AM
Red Hooter
Sep 8, 2005 02:44 AM
