Replacing my CCT
Old Jan 19, 2011 | 08:44 AM
Jeff0044's Avatar
Default Replacing my CCT
I bought an APE manual CCT and Gasket from
http://www.streetandcomp.com/store/i...&FromNav=False
I will be putting it on myself but I was wondering if there is anything I should know before doing so also the whole turning something to TDC #1 how do you know if you have to do that and how would I do that if I have to?
All answers appreciated thanks
Old Jan 19, 2011 | 08:52 AM
kazspeed's Avatar
Check out the sticky tittled "The CCTL Thread". There is a bunch of information in there.
Old Jan 19, 2011 | 08:53 AM
Jeff0044's Avatar
Ya I have read it before but I was kind of hoping I could get some quick answers and be lazy :P but I'm probably going to get a lot of answers like yours so I'll just check it out
Old Jan 19, 2011 | 11:19 AM
mbison83's Avatar
i would say replacing the cct is pretty straightforward. take the old one out, and even tho the stopper tool is recommended, it is not needed since you're not going to be putting it back in. i've never installed the manual cct, but heard guys using blue lock tite on the threads to prevent the nut from loosening up. look it up to make sure.
Old Jan 19, 2011 | 08:11 PM
motorhorse's Avatar
i wouldnt worry too much about a stopper tool, however it is critical that you loosen the upper and lower bolts evenly or you could trash the threads.
the TDC thing isnt necessary. lock tite isn't either but it would help im sure.
use a 1/4" swivel, ext., + 5mm socket. although its possible w/ 3/8", its not worth the frustration...
Old Jan 24, 2011 | 07:03 PM
Jeff0044's Avatar
Thanks for the replies I got it in the mail today so hopefully I don't totally mess my bike up ugh I'm scared to try and put it in lol
Old Jan 24, 2011 | 08:34 PM
crazychris1981's Avatar
i have pretty big hands to be working on these compact bikes.. i found the easiest way for me to get in there and have room was to lift tank using a ratchet strap and removing the radiator over flow bottle. of course the seat will have to be off.. then go in from the left side of the bike and it's right there.. doing it this way i was able to get both my hands in there to start the bolts without cross threading them... but i would say what ever works for you is the best way....i'm not a bike mechanic but if you are lazy i would say to go and buy the stock style tensioner... that way you wont have to adjust it when it needs to be done like the ape or other manual ones...just replace when it goes bad...
Old Jan 25, 2011 | 12:25 AM
Jeff0044's Avatar
I already bought the APE tensioner it came today but I just have to figure out how I am going to fix this.. I'm off work Thursday so I might try then because it's supposed to be 55 degrees and I want to ride!
Jeff0044
Mar 22, 2011 07:57 PM
Juggalo_X
Jul 18, 2008 02:05 AM
crunkchris
Jun 22, 2007 07:00 PM
cblynn04
Mar 27, 2007 04:27 PM
jayking232003
Mar 18, 2007 02:57 PM
